I need to have a text to robot voice converter. What software do I use? Is there any online site that serve text to robot voice converter free? Please give me some advice on how to use them. Thanks
Where to find a text to robot voice converter free?
There are online sites like ABC2MP3.com where you can choose between 4 voices
or http://www.festvox.org/voicedemos.html where you can choose from 12 audio voices
If you want a software you can download 2nd speech center and use it in few simple steps :
1) Â Download and extract
2) Â Install
3) Â Run the program
4) Â Enter the text and press "Speak"
Hi Centic,
You can use the following link to convert your text material to robot voice. This is an online service, so you need not install any software for this. This is also free to use meaning you need not pay anything to use this. This is extremely easy to use and I do not think you will take time to see how this works.
Hope this helped!
Drianna allen
