Where to find time report template for Mac? I am using a Mac operating system and having a hard time on getting the right one. Sometimes the error says unable to download compatibility measurements and other specification which is not compatible with each other. To all Mac operating system users can you give me the right website to download time report template for Mac?
Hi Debra Carter,
I have found a site that may help you in finding the best time tracker in Mac OS. It features 8 Excellent samples of Time tracker. I have attached the link below for your reference.
AppStorm Mac: 8 Excellent Time Tracking Utilities for Mac
Hope that it would help you a lot.
Thanks and have a good day.
Hello Carter,
There are lots of time tracking apps available for Mac. Among them Klok is the best. Strait forward time tracking and entry system, which is flexible and user friendly interface.
Features
Track any project
Drag & drop time entry
Dashboard overview
Multiple project option
Automatic updates
To know more and for download please check the link.
Hope this will help you.
Thank you.
