Hello everyone,
I am in need of wireless signal strength program.I looked around and could not search any.So,i need a good freeware that not only displays the signal strength in percentage but also keep updating after every 10 seconds.I need this program for my windows 7.Recommend me any good software.
Where to find wireless signal strength program?
Hi Jeffrey,
I found a wireless signal strength program that could help you monitor your wireless connection.
 inSSIDer – this program is compatible with your windows 7 (32 or 64 bit) . This one can help you monitor the signal strength, sort connections by mac address, SSID and channel. This is not exactly what you wanted but this can help you out monitor your wireless network. You can get it at this website. https://www.metageek.com/products/inssider/
Hope this help!
Browning Wallace
Hi Jeffrey, thank you for your question.
If you are looking for a good program just to check your signal strength, you can go for the popular WIFI Signal Strength, it refreshes its information every five seconds and can stay on top of other windows and can be placed anywhere on the desktop. It displays both the SSID and the signal strength. Others that you can check on include: WiFi Signal, WiFi SiStr, AirGrab WiFi Radar among others.
I hope this will help you.
Ramirez William
