Where to find xp Mac support?
Hi there! I need to know if there is such thing as XP mac support? Does running windows xp really supported by mac? Kindly explain how. Thanks so much.
Hi
The new MacBook allow users to install window operating system in it as apple is using Intel processors. But you need virtualization for mac support in window. VMware provides you to virtualized mac operating system. you can get help from the below video. In this case you can run two os in parallel at same time.
Thank you
I think that virtualization can solve your problem. You need to download virtualization software which is compatible with MAC. Then you can use Windows XP in MAC.
Thanks
