Where to get Adobe player compatible Samsung wave 2?
I was wondering if there is adobe player compatible Samsung wave 2, available. If someone knows, then tell me where to get? Any kind of help would be appreciated.
Hi Deborah clink,
It is quite difficult to find out the appropriate version of adobe player for your model.
You can try the link of the following which has a wide collection of adobe players.
http://www.downloadcollection.com/freeware/adobe-flash-player-for-samsung-wave-2.htm
Start downloading and keep trying.
Or you can also try to check on the link below if the Adobe Player will work on your Samsung Wave:
http://www.fileguru.com/apps/adobe_flash_player_samsung_wave
Hello Deborah,
As of now you cannot be able to use adobe flash player on Samsung Wave 2 because it is not supported by the device. To be able to use the adobe flash player you will need to be having an android device or an iphone. But hopefully the manufacturers will be able to come up with a way to fix that issue in future.
To be able to stay up to date with any details concerning this matter, I will suggest that you do the following:
You can contact their support staff directly and ask them more about this issue.
Carl
