I bought an Asus and it came with Windows 7 already installed. I would like to change to Windows 8 but before upgrading I wanted to know where I will get all drivers. On the Asus website I can seem to find drivers for my model. Can anyone tell me where to get drivers for Asus K53SV?
Where to get Asus K53SV Windows 8 drivers
Hi Curtis,
1) The Windows 8 drivers for Asus K53SV are available in the download driver website
2) Download the drivers from the website. It is license free. The files are in Zip format.
3) Unzip these files and install them in the Asus K53SV
4) Restart the system after the installation is done
Hey there!
Simply go to ASUS official webpage. Remember that when you need any drivers, you should first go to your PC or laptop's manufacturer official page. You can find all the drivers you need from there. Here is the link to where you can get the drivers you need for your ASUS K53SV.You can find the driver for Windows 8 64-bit.
