Please give me the information! Where can I get border FX plugins for Lightroom 3?
I need them for my photo as well as for aperture to make it really impressive.
I will be waiting for your reply.
Where to get border fx Plugins for lightroom 3?
The Plugin Site has a wide range of plugins for Lightroom to choose from such as borders and filter effects,
There are many different photo effects plugins to choose from that will allow you to:
Fix lighting problems
Adjust skin tones
Remove noise from photos
Increase the amount of different file types that Lightroom can import
Sharpening photographs
Create black and white and sepia photos
Onone software also has great programs that can be used as plugins in Lightroom or as a stand-alone software.
If you are looking for a plug-in compatible with Lightroom, I suggest LR/Mogrify. It lets you use ImageMagick’s mogrify command on the images you exported out of Lightroom.
It offers user-friendly interface for easy control use of its features.
You can do advanced resizing, adding borders and more. It’s pretty cool.Â
You can check the steps here on how you can install the plug-in.
