Hi all experts,
I am working on a project to produce flowcharts and process flow diagrams. For this project I need a database management screenshot so that I can easily maintain and produce flowcharts depending upon varieties of conditions and situations.
Where to get database management screenshots.
Hi Dallas,
For flowcharts and process flow diagrams I will recommend using SmartDraw. SmartDraw has automatic formatting, quick-start templates, and also has free support. Your project will be much simpler because SmartDraw builds the flowchart for you automatically. It also realigns and arranges all elements so that your chart will look nice and clean. Go the link below and use SmartDraw for free.
https://www.smartdraw.com/flowchart/flowchart-maker.htm
Hope it helps,
Korber Owen
