I have been using Adobe Photoshop for quite some time and I just decided to try using Corel Draw for a change for skill expansion. I may like it better than Photoshop. I am looking for drive exe Corel draw so I can legally download and install one on my PC. I need a specific installer that would be compatible with my Windows 7 machine.
Thank you so much.
Where to get drive exe corel draw?
Try this CorelDRAW installer that would be compatible on your Windows 7 operating system.
https://www.coreldraw.com/en/pages/free-download/
Corel company discharge their latest creation, the CorelDRAW X6, which is a development from preceding edition of CorelDRAWX5. CorelDRAW X6 is the finest software in the ground of graphic drawing. CorelDRAW X6 is increasing ideal in terms of graphic drawing.
Best regards,
Heather Marie
Following use PDF always I always want to use information files in Corel:
First of all, install any program to print in PDF (acrobat pro 4.0-7.0-comercial, or any program freeware like(as) ghostscript or pdf995 or looked etc. in simtel.net).
Impression of Excel / Word to pdf-printer (if it is possible, in the configuration of the printer I used sources to curves, because the import of coreldraw).
Now to import this PDF in coreldraw, as what you will have native Corel objects – the text lines(figures), etc.
If you are necessary, select the imported objects and to do them cmyk.
This is the best way that I know for files destined for the impression in offset.
