Where to get drivers 9530 Blackberry Storm USB?
I have researched a lot for drivers 9530 Blackberry Storm to connect via USB but I’m unsuccessful. Does anybody know where to find drivers? Any kind of help would be appreciated.
Hello.
After a quick research on the internet I finally found some websites with the information about blackberry drivers.
You can download the drivers from its official website.
Click on the below link to download drivers
To know more about the driver installation click on the below link drivers download
Before installation, the following must kept in mind:
i. Desktop and handheld software may be installed on the hard drive.
ii. Ensure that desktop software be installed first and then handheld software on the computer.
You can download software for 9530 Blackberry Storm from the following link
If you have a BlackBerry Storm 9530 Smartphone and you want to install its drivers on your computer so you can connect it to your machine via USB cable, you don’t need to specifically download its drivers because there is no such thing. To install its drivers, you need to download the BlackBerry Desktop Software 7.1.
This version is designed for BlackBerry Smartphones running on BlackBerry 7.1 OS and earlier. The BlackBerry Storm 9530 Smartphone that you have is running on BlackBerry 5.0 operating system. For Mac users, download the BlackBerry Mac Desktop Software 2.4. There are two BlackBerry PC software available for download on the BlackBerry website: the BlackBerry Desktop Software 7.1 and the BlackBerry Link.
The BlackBerry Link software is designed for BlackBerry Smartphones with BlackBerry 10 operating system. Since you have a BlackBerry Storm 9530 Smartphone, download and install the BlackBerry Desktop Software 7.1 and not the BlackBerry Link software because it won’t work. When it is installed on your computer, you will now be able to connect your BlackBerry Smartphone on your computer using the USB cable that comes with it.
Notifications
