kawinzi
Posted on - 11/18/2012
I have acquired Express gate; the instant OS software that you can turn on and use without loading windows, but it is not working in my PC!
I have been advised to download Express gate wireless drivers for it.
Any suggestions where I can download them?
Where to get express gate wireless drivers and software
Good day Kawinzi,
Here are some of my suggestion to you. Though the advice is really good, this is what I will recommend to you.
This is the link where you can download the files.
The advice is really good and I will recommend you following links I hope they will solve your issue and you can download the required files.
Just select your OS and the Bit of it.
Thank you and god bless.
Hope this help.
Support Asus Download
Vip asus forum view
Kindly select the windows type like (Window xp, Windows 7, Windows RT and Windows Server etc) and kindly do select 32 bit operating system or 64 bit Operating System option.
Regards
JK
If you are referring to ASUS Express Gate, I think it is part of the motherboard which you can access by going to the BIOS. This means you need to have an ASUS motherboard that supports the ASUS Express Gate technology. It is a technology developed by ASUS and introduced with their P5E3 series which uses Splashtop. Splashtop is a Linux environment built-in to the ASUS motherboard.
This technology allows users to turn on their computer and in just five seconds can have access to the internet using Mozilla Firefox, Skype, online email, and the Splashtop desktop. These features are available and can be accessed while the operating system on the computer is still loading.
If you want to disable ASUS Express Gate, restart your computer then press DEL, DELETE, F2, or whichever key is configured to go to the BIOS. In the BIOS, go to “Tools” tab then under “Express Gate” change the setting from “Enabled” to “Disabled”. Press F10 to save and exit. And that’s it.
