Where to get firmware for Samsung h1 Smartphone 2011 version
I have a Samsung h1 smartphone and want to get firmware for the year 2011 version. Please tell me the link to get firmware Samsung h1 2011 version.
I’m not sure if you can still upgrade your Smartphone to last year’s firmware version since it is already not the latest version. It would be much better if you will just upgrade your phone’s firmware to ICS or Ice Cream Sandwich which is already available since May 1 of this year, 2012.
You should check first if your device is compatible to be upgraded to Android 4.0 ICS. To learn on how to upgrade to Ice Cream Sandwich, please visit SAMSUNG — Useful Software for Mobile Phones. If the above upgrade is not supported by your phone, check the information posted on BOARDS.IE — Samsung H1 Firmware Update for a possible solution to your problem.
Notifications
