Where to get free download for snow leopard winamp?
Where to get a free download for snow leopard winamp? I just got this new Mac snow leopard operating system and I am having a hard time on dealing with it for this is my first time but it’s alright as long as you will guide me along the downloading and installation process. I hope you can give me some advice and suggestions for this.
Thank you.
Best Answer by Johnstoon Leen
Answered By 0 points N/A #181240
You might have problem in searching software because you were searching with version of the software you need to search with just an operating system name such as Mac in this case. Every flavor of mac support same extensions for installation. I am adding a few links from where you can download and run winamp and other multimedia tools.
The last link is very authentic.
Thank you.
Answered By 0 points N/A #181241
Hi Jayden Horribal,
First you should learn the basic concept.
If you want to run the windows app on Linux or Mac you definitely need a tool which will run different windows apps on your Mac or Linux OS.
I am recommending you a highly rated tool which is very easy to use in Linux and on Mac too.
  1. “WINE” the tool which you have to download and install it.
  2. Run the WINE tool and now you can easily download the window app “WINAMP LITE (Free)” from WINE tool.
  3. After doing this, install the app WINAMP and try to select WINAMP classic skin.
  4. In case that makes a difference.
  5. You have snow Leopard, so this all works for the latest OSX for MAC.
Enjoy and Have a Fun!
Jhonstoon Leen
