Please tell me where to get an FTP editor google chrome compatible. I have been told that there is no FTP client with chrome. Is this true? Is there a workaround for this? Let me know if you have a way to have FTP on chrome
Where to get Ftp editor Google chrome compatible
You can have your required FTP editor from the following page,
https://chrome.google.com/webstore/detail/ftp-editor/caljonifjecojdgoejokjfdffgpgliic?hl=en-GB
Full featured FTP client for Google Chrome has the following features;
·        Edit, upload and download files on your FTP server.
·        Securely saves login details for all the FTP servers.
·        Creates new files on FTP server.
·        Easy to use GUI.
Good luck.
Hello Dorothy Davis
Hope you are well. There are several FTP editors which are compatible with Google chrome. Google chrome has a web store and there you will find Google chrome FTP editor. You can view, edit, download and upload files on your ftp server. You can get it from Google Chrome web store or Google product forums. You have to sign in with your Google ID to add this add on Google Chrome. Hope this will help you.
With Thanks
Greaney Mary
