Where to get latest version of BT Versatility Firmware?
I want to upgrade Firmware of BT Versatility to latest version and was wondering if someone may tell me where to get BT versatility firmware?
Any kind of help would be appreciated.
The BT versatility Version 9 firmware upgrade is a software which improves the speed of your phone system, enables latest features, reduces systems breakdowns and keeps call quality at a good clear level.
Try visit this page might help for your problem.
Hello Caecil,
The best place to get the BT versatility Version firmware will be from the manufacturer's website, and therefore you can access the site here to check it out here:Â
The following are the improvements in the BT versatility Version firmware upgrade:
Note that the upgrade is an essential upgrade for any BT Versatility system that has been used for over 2 years.
It will keep your phone system as well as the business running efficiently.
Carl
