Where To Get Microsoft Picture Manager Free Download 2013
I have deleted some system files by mistake, and now my photos are not opening in my windows. Where can I get Microsoft picture manager free download 2013 for my windows?
Although Microsoft have ended support to picture manager in Office 2013 but it can still be downloaded on various others sites which are distributing the Microsoft office picture manager. You can use Microsoft word to edit the photos also in case you want to. The link for one of those sites is given below.
http://download.cnet.com/Microsoft-Office-Picture-Manager/3000-2192_4-76476831.html
According to Microsoft, the Microsoft Office Picture Manager or simply Picture Manager is no longer supported in Microsoft Office 2013 and newer. If you still want to use Picture Manager, there is still a way by installing it as a standalone application using SharePoint Designer 2007. You need to custom install this application to install Picture Manager. First, download SharePoint Designer 2007.
On the “Choose the download you want” screen, just check only “SharePointDesigner.exe” and click “Next.” Once the file is downloaded, double-click the installer to start the installation. On the “Choose the installation you want” screen, select “Customize.” Expand “Microsoft Office SharePoint Designer” and select “Microsoft Office Picture Manager.” Click the dropdown arrow next to “Microsoft Office Picture Manager” and click “Run from my computer.”
Click “Install Now” to begin installing Microsoft Office Picture Manager. If you have Microsoft Office 2010, Microsoft Office 2007, or older, the Microsoft Office Picture Manager should still be included in the package.
Notifications
