Where to get miui 1280 720 version for android
HI, I need miui 1280 720 resolution version for android. Is it available and is it compatible with my Samsung galaxy s3
Thanks
Thanks
Hi Ayannahana,
Your are asking for an existing for a MIUI 1280×720 resolution version for android and my answer is yes, there is. However, on the issue of compatibility, that depends on your unit. Is it a Samsung Galaxy S3 I9300 international version? If it is not, then it is not compatible. If it is an international version, the MIUI version will work. All you need is a PC with a Windows operating system. Then, go to the official MIUI Official site. In the download tab, click galaxy s3. Follow the installation guide.
“MIUI,” pronounced as “Me You I,” is a custom ROM for Android Smartphones and tablets developed by Xiaomi, a Chinese electronics manufacturer. It is powered by Android mobile operating system and includes features like theme support. Xiaomi released several Smartphones with Android One while others have MIUI which is based on the latest Android version.
Xiaomi devices normally receive one Android update but get MIUI updates for four (4) years. Because of this, different apps and features were not available in the aftermarket version of MIUI but available only via rooting. Xiaomi said in February 24, 2016 that the MIUI ROM had more than 160 million users worldwide and was supported on more than 678 handsets.
In Android, there is no such thing as downloading or installing a stock ROM or custom ROM for a specific screen size. The screen size depends on your device.
Notifications
