Where to get Pokemon platinum for blackberry bold?
I have blackberry bold and was wondering if someone will tell me where to get Pokemon platinum for blackberry free of cost? Any kind of help would be appreciated.
Kindly follow any of the steps here.
First you must install a Game boy Emulator on your Blackberry Bold. You can download Pokemon for your blackberry bold here at http://www.blackberryseeker.com/ you can also download directly the Pokemon games here. Choose Pokemon in the search tab and change the all items option to games. There is also a second way to install a Pokemon games through Java.
First you must have Blackberry Desktop Manager Software in your computer. Next download the Pokemon from this link
Next, connect your blackberry to your computer and open the application tab. After that, click import and select the file “Yellow.alx” then click the button that appears and says apply.
Hope this helps!
The fact that these cards have a very close relationship to the Pikachus series is what gives them value. The value of a Mega EX card is the 34th-highest value ever recorded for a Pokemon card.
Cards from the EX series can hold a value of $34,000 whereas those from the EY series have a double value. The series #178 cards, which belong to the EY community, have a value of $75,000 each. The other copies aren’t worth as much, but they still have a $9000 value.
