Where to get Samsung series 5 codec for .mkv?
I have Series 5 Samsung LCD and was wondering if there are Samsung series 5 codec for .mkv? Any kind of help would be appreciated.
The codec for .mkv files are not obtainable in the web. You have to use converting techniques for playing this kind of format. But it may less the quality of video.
Try to visit and read the issues in the forum showed here. There are many suggestions to play this file through LCD display.
In fact Samsung television support playing many types of videos via USB and MKV is one of these types that is supported, but why it does not work. When you try to play it you will see only video without sound. This as the sound encoded with the code of DTS which TV could not support it. So you have to change the encoding of these videos using programs like popcorn audio converter to have the format of AC3 that could be played.
Hello dear,
You should use a CODEC pack to play this video file. MKV files are very high definition videos. With a large quality resolution video, I suggest you use the K-Lite CODEC pack to run these files smoothly. K-Lite CODEC pack is very easy to install and use. It supports all file types. You can download it from this link.
http://www.free-codecs.com//www.free-codecs.com/download/k_lite_codec_pack.htm
This link is for K-Lite CODEC pack version 9.7.5. It will remove your problem. Thanks.
Notifications
