Where to get Ubuntu Acer Bluetooth drivers
My Acer Aspire 5742G laptop have Ubuntu x64 installed inside windows 7 x64.
Its Bluetooth is not working due to driver issues.
Please suggest me on where to get Ubuntu Acer Bluetooth drivers.
Hi Anderson,
I think I can be able to help you in solving your problem or the issue you have at hand.
The Ubuntu Bluetooth drivers for Acer Aspire 5742G laptop can be found and downloaded from the website;
Once you download the drivers, you will be able to install and follow the prompts to install.
You can also use a driver update utility;
You can then restart or reboot your computer for the settings to take place.
Open the software to test and it should be working well.
This should solve your query.
Notifications
