roger neil
20 points
Posted on - 04/23/2013
I need a windows phone printer app so I could print documents directly from my phone like a regular PC.
I checked that there are some apps that don’t work this way.
I don’t want to upload my files on the internet for me to be able to print.
Is there an app I could install?
I hope I could I have also have one that could work with wireless printers.
Where to get a windows phone printer app
You can use Robo Print app for your windows phone. This app will help you to print the contents through your phone.
You will only need to secure a reliable internet connection for your windows phone and printer so that a connection between them is made.
Another good thing about it is that you can print your e-mails, you can create profiles for easy printing anywhere you are as long as you are connected to the printer.Â
You can download Robo Print here.
Hello Roger,
It looks like you are looking for a printer application for your Windows phone. You have not mentioned which version of windows Phone you are using. Its very difficult to get a printer application for windows phones but you can try Robo print application. Using this application, you can print your e-mails, can create profiles for easy printing also.
You can download this application from the following link
You need to keep in mind that a printer application can't directly access office's document storage, so the office app would have to provide the print feature itself.
However, any application can access SkyDrive or any other cloud storage provider.
I hope this helps.
Hello Roger,
Given you have a problem related to windows phone I want to guess that you also have a windows PC.
There is an app called Dropbox that you can try  and see if it solves your problem.Here is how to do it:
1. Download and install Dropbox on your computer from this link by clicking on the eprint.vbs file
2. Download a Dropbox app on your mobile phone
3. Upload your file through Dropbox mobile app and wait for the printing to be done.
