When I download something from internet in Google Chrome browser and I open it once then it vanishes from the Google Chrome browser, I want to know that where this file is actually downloaded, thanks in advance.
Where the Google chrome downloaded files go?
Hi there,
Whenever you download something in Google chrome, it goes to the LOCATION which you have decided for the downloaded files.
As soon as you click on some file to download it, it starts downloading and you can see the whole of the status by using the following links:
Chrome: //downloads/
As soon as you're downloading gets completed you can view your downloaded file by clicking the "open downloads folder" on the right corner of the window which opens when you go to the above mentioned link.
You can also see the status and location of your downloaded files by using keyboard shortcut: "Ctrl + J".
Good Luck.
After your confirmation about that is it already 100 percent downloaded your file you may visit to your computer local disk C whereby the download files is save and check the downloaded files and try to open it and play it, try to forward up to the end and if it is running means downloading is completed.
Best of luck.
Downloaded files can be seen at the download bar found at the bottom of the Google chrome browser. Some user thinks that they lost their downloaded files once they accidentally close the browser. To locate all the download files there are two options.
1. The easiest way to track is to press "SHIFT+J".
2. If the file can't be found using "SHIFT+J" command,
Go "options" (Located where on the right side of the browser) then click " SETTINGS" scroll down the page until you found "Advance Settings", scroll down again and you will see "DOWNLOADS" and you will able to locate where your downloaded file is saved.
