Where I can buy mind power algebra, price should be low.
Hey,
I heard about Mind power math which is very effective by which I can easily learn from my PC. As it is not free anyone can tell me where I can buy Mind power algebra, price should be as low as possible.
Best Answer by Thornton Patricia
Answered By 0 points N/A #163574
You can get cheap mind power algebra from amazon.com here type mind power math in search bar by selecting software category and then choose education and reference type and then select secondary education then click math in dropdown list which is in left side of search bar which is compatible with windows and mac.
it is having good ratings
Hope these shall helps you
Thanks
Answered By 0 points N/A #163575
Mind Power Math is developed by The Learning Company. It's now used by Software Informer.
You can buy it from Amazon.com. The price is around $20.
You also can buy it from the ebay.com. The price here is around $21.
Just go to these sites, type in Mind Power Math, and search.
