kurt tedo
10 points
Posted on - 02/05/2013
I need to check for hardware problems on my HP laptop.Â
Is there any website from where I can download HP hardware diagnostic boot CD to do this?Â
My laptop runs on Vista, I don't know much but maybe that helps.
Where I can download hp hard+B8822ware diagnostic boot cd
Hello Kurt,
There are several ways you could try and fix your HP laptop hardware problems. For HP it's always suggested to use Hardware Diagnostic Tools by either testing from the BIOS or from the hard drive itself. So far my knowledge, the diagnostic disc only comes with HP server but not with laptops or desktops. If that's not enough, then you better take a look here for more details:Â
You can also try or check this link to find out if you can download the diagnostic boot CD:
I think the above two sources will be enough to solve your problem.
