A Bagul
Posted on - 07/26/2016
Hey guys,
I have some Hyperlinks in my Word Document, and I’m looking for a method by which I can convert the Word File to a PDF File without losing the Hyperlinks. Somebody, help me to Create PDF with Hyperlinks from Words.
B Potts
10 points
Where I can find Add-on to Create PDF with Hyperlinks from Word?
You will have to download an Add-in to save the Word File as a PDF File. Microsoft Word 2007, originally, does not allow saving Files as PDF. You can download the Add-in from https://www.microsoft.com/en-in/download/details.aspx?id=7.
When you download it, install it on your PC. After that, restart Microsoft Word.
Open the Document that you want to turn into a PDF File. Click on the File Menu on Select Save As Option. In the Save As types, you will find PDF. Click on that option, and select “Publish.” After that, you will see the PDF version of that Document.
