Where I can find free Media Player for rmvb files Mac
Hi
I am using mac operating system and I cannot play RMVB files in my computer. I need a good media player to play RMVB files for free. I need to know the best version of it.
Thanks
Hi
Thanks
Hi Marcellatierra,
Very simple Real Player can play files both created for MAC and PC all file format RMVB, WAV, FLA, MP4, 3GP etc a smart player from which you can not only play your media but also download and convert music or video files.
Latest and best version I recommend you to download is 15.0.6.14 it’s free on real player website.
Hi Marcellatierra,
Solution 1:
The Ultimate Player to play all files is VLC Media Player. It will play all formats,
Solution 2:
If u do not interest using the VLC player the other option is "Perian" it can be used in MAC Operating System.It cannot play wmv file extension.If u want to play wmv files through Perian then you need to add Flip4MAC then it can cover wmv files also.
Solution 3: Try Real Player it can also be used to play rmvb files.
Thank you.
