Where I can find the powerpoint number counter?
Hello fellows,
I need your help. Where I can find the PowerPoint number counter? Is it a built in software or a downloadable one? I need this kind of application for my PowerPoint presentation.
Thanks
Best Answer by Sufika Sanjso
Answered By 5 points N/A #132833
Hello Rhonda A Inouye,
Yes, It is built in software not to download. You can find the PowerPoint number counter do the following step.
  • Click on the file menu.
  • Click on the properties.
  • Click on the statistics tab.
  • Find out the number counter.
This way you can find out the desired result.
Answered By 0 points N/A #132834
PowerPoint number counter is an important thing to make a nice presentation. Here is some session for you-
Place the images wherever you want. Select the first image and add an animation to it. Then right click on the animation Choose Start after Previous.
Then, right click on it again and choose Timing. Set Delay for just 1 second.
This is the easy process. You can set the first one to ‘On Click’ instead of ‘Start after Previous’, so the count wouldn’t start until you click or press space bar.
Hope, this can help you.
