Where I can find vmware network traffic monitoring application
Asked By 110 points N/A Posted on -
Hi I want to trace and monitor my network in vmware. Where I can download such application or software vmware network traffic monitoring  that I can capture’s to those of passing through to my network. So that I can minimize and trace where is the part of the network has low part. I hope you can help me to find a software. Thank you.
Answered By 5 points N/A #199331
Try using the LANGuardian to monitor the VMWare physical and virtual networks. It allows you to monitor the virtual network traffic just like the way you monitor it on the physical network. It brings combined monitoring for the physical and virtual network with one user interface.
It seizes and analyzes data packets running on the core switch of the network and then save the details on the database and then submit the data on the browser.
