From where I can get a Excel to PDF converter for free
Dear,
I have some important documents which are now in excel format. I need to convert them to PDF format because of some necessary issues. So, I need to download a free Excel to PDF converter which I can depend on.
Thanks
Answered By 0 points N/A #158852
Hi Garrick,
You can do this by installing PDFCreator, which is free for d/load at: http://www.pdfforge.org/
To use this conversion: when you select your PDF file open it using default program, and set up your printer, by selecting a PDFcreator as a printer of choice! This gives you direct excel to PDF conversion.
First image is Monitor, second one is Print manager, and last image shows Options menu in PDFCreator. Hope that this helped!!
Answered By 590495 points N/A #327320
If you need to convert some Microsoft Office Excel files to PDF format, go to Convert documents and images to PDF. The service allows you to upload your files in four (4) ways: URL, Dropbox, Google Drive, and by selecting it directly on your hard drive. The tool allows you to set several options before you convert. When you are ready, just hit the “Start conversion” button.
When conversion is complete, the file can be downloaded immediately and you will not be asked to provide your email address just to download. Another service you can try is Excel to PDF Converter. Just like the previous one, it allows you to upload by URL, Dropbox, Google Drive, and from your hard drive.
