Desk-bound in front of a computer screen for long durations can intensely increase the risk of insomnia and depression. It also causes headaches, backaches and eye strain. Due to these reasons, I want to install Sery computer time limiter software on my computer but I don’t know from where I can get this?
Sorry to hear that kind of scenario you have. We experience the same set-up therefore I know what you’re feeling right now. It’s a great idea that there is software available to keep track of our time using computer thus aids us to be healthy and less prone to sickness.
For your concern, there’s one site wherein you can download the Sery Computer Time Limiter Software. Aside from Sery, you can also try using another computer time limiter. These are:
Kioskea Computer Time Limit – This free downloadable version software monitors the computer usage and also helps the user set perimeter for every hour used.
Nicekit Software Time Boss – This software help user to be flexible in using a computer, and it is very easy to use.
You can also visit here to learn how you can limit Internet time use. This is designed mainly for children but it will be beneficial to adults too who are working non-stop on the computer.
I’m not sure about “Sery” but if you want to use a time limiter or a computer usage limiter, try Computer Time Limiter from Suncross. It supports Windows XP and Windows 7. The developer doesn’t mention Windows Vista but you can try if you have this version. On Microsoft Windows 7, the program has to be started with admin privileges.
Computer Time Limiter by Suncross
If you want to use it on demand, just right-click the application and select “Run as administrator”. But if you want to use it regularly, you can set the program to always run as admin in the properties. Right-click Computer Time Limiter and select “Properties”.
In the “Properties” window, go to “Compatibility” tab then under “Privilege Level” section at the bottom, check “Run this program as an administrator” then click “OK”. This will always run the program with full administrative privileges. It can also be used on Windows 10 but it has more issues.
According to Suncross, on Windows 10 “not all warning messages to the user that is (almost) out of time are shown properly”. CTL or Computer Time Limiter is a parental control application that enforces limits on computer time usage. It allows users to manage and control how long when the children are using the computer.
1....
