Where I find tool change modified date increment?
Hello guys, I need best tool change modified date increment software.
Can you tell me where I can download the best tool change modified date increment software?
Please provide download link with details about it. If you can provide step-by-step tutorial about this will be fantastic.
I want pro version so do not provide trial download link.
Best Answer by Emily Hopkins
Answered By 30 points N/A #171653
In this case I will prefer DirDate software. It is very easy to use and automated to change your files.
It will also help you to create date or last access date. You can change the current time or year, month series.
And another thing is it has preview mode to see modified files.
Answered By 0 points N/A #171655
Hello!
Here is another option if you are looking for Modified Date Increment Software. The FileDate Changer utility allows you to simply change the Created, Modified, and Accessed dates of one or all of your files. Let me know what your think or if you have any questions on the software. Thank you!
