Where I will get flash lite 4 for Galaxy ace?
I bought a Samsung GT S5830T Galaxy Ace about 2 weeks ago.
I need to get flash lite 4 for galaxy ace.
Where I can easily get or buy it?
Hi Annita,
There are too many sites for you to get the "Flash lite 4 for Galaxy Ace'.
You can get it free from some sites.
Here I am going to give you two site's name. You can get the app free from there.
I think you will find your solution here.
Hi
You want to download Flash Lite for Galaxy Ace. On Internet you can find many of them.
On many pages, the free versions of the app found.
This link that help you to get this:
Hope these shall help you.
Hello Laura Annita,
Hi you can use an application called as FLASHLIGHT-LED .
You can get it from the Google apps page here this software supports galaxy ace and should work proper .
The software can help you make use of flash light bby using the LED light at the back or can also be used by making the screen completely white and therefore giving you a makeshift flash light .
Thanks!
