Where Is Sysprep Location Windows 7 On A 64-bit System?
Hello friend,
Please tell me about the Sysprep location Windows 7? I am currently working on HP notebook and Windows 7 operating system.
Thanks in advance for help.
Hello friend,
Step1. Assuming Windows 2008 server is on your system. The very first step is to go to c drive and go in windows folder.
Step2. Open the folder and search system32.
Step3. Select the sysprep folder and open it.
Here is you can find your sysprep for Windows7.
*Either you can follow the above steps or simply type the address C:\windows\system32\sysprep\sysprep.exe.
Step4. When you will click on the .exe file of sysprep you will get the dilog box and can perform your other required tasks.
