Where Is Windows 7 Home Premium OA Download 64 Bit Available?
I want to know about OA 64 bit. What is OA 64 bit? Where is Windows 7 Home Premium OA download 64 bit available?
Authorized producers make the OA versions of the operating systems. They provide the facility of easy activation of the version as the product key is already with them and they unlock the version in the safest mode. The OA version is available in both 32 and 64 bits.
Windows 7 Home Premium OA 64 bit is obtainable on the Internet. There are sites which provide us this facility, and they assure us about their compatible operations. But also always choosing a licensed version given by the authorized produced is the best step to choosing as those versions come without any troublesome issues. And as OA versions are easy to unlock, the process doesn’t take much time and effort of a user.
The “OA” part in Windows 7 Home Premium OA is actually “OEM Activation”. It basically means the operating system or Microsoft Windows 7 Home Premium is already activated and you don’t need to activate it yourself. “OEM” stands for “Original Equipment Manufacturer”. When your operating system has an OEM license, it means the license cannot be transferred to another computer.
OEM licenses are designed to be installed by the system manufacturers only. They are not intended to be sold to end-users or customers and should be preinstalled on a computer. An OEM license is bound to the computer where it is originally installed. You cannot transfer or move the license to another computer.
If the computer is installed with an older operating system, you cannot use the license to upgrade the operating system. The only way to use the license is to perform a clean install.
