Where Is Windows 7 Home Premium SP1 64 Bit Download Available?
The Service Pack 1 64 bit includes few updates of the old operating system versions. The service pack facility is available both on 32-bit processor and 64 bit processor. Windows 7 Home Premium 64-bit automatically installs the SP1 into the computer. But if there is no such thing, one can always use the System Update option visible on the Control Panel.
To check if the Service packs already exists, right-click on the Computer icon and check in the properties. If it mentions “service pack 1” it means that the operating system already has the service pack in it. A user can also download the version with service pack on the Internet, but need to take care of the safest download
If you have 64-bit Microsoft Windows 7 Home Premium and you want to update your operating system to Service Pack 1, go to Windows 7 Service Pack 1 then download and install the Service Pack update. This is the latest and only Service Pack update for Microsoft Windows 7 both 32-bit and 64-bit. This update also applies to Windows Server 2008 R2.
This update helps your computer and server on the latest support level. It offers continuing enhancements to the Windows operating system by incorporating previous updates normally delivered over Windows Update. This update also offers continuing incremental updates to Microsoft Windows 7 and Microsoft Windows Server 2008 R2 operating systems according to partner and customer feedback.
Installing a Service Pack update allows organizations to set up a single set of updates. The Windows 7 Service Pack 1 update was announced on March 18, 2010 and its beta was released on July 12, 2010. On February 22, 2011, the final version of the Windows 7 Service Pack 1 update was released to the public.
Windows 7 Service Pack 1 enhances IKEv2 by adding extra identification fields like email ID and adds support for AVX or the Advanced Vector Extensions which is a 256-bit instruction set extension for processors.
Notifications
