I have purchased Lenovo usb web camera recently. I am having trouble in installing the web camera software as it is asking for serial number and the number written on the camera does not work. Does anyone know where webcam serial number is specified?
Where is Lenovo USB web camera serial number specified?
Hello Jonathan,
The number written on the camera may not be the same one to use when installing the webcam software. If you installing the software from a CD you will need to check to the following:
Insert the CD into the DVD drive.
Wait for some time for it to load and then go to "My Computer" and click on it to open it.
After it opens, locate the CD drive and then right click on it.
Choose Autoplay.
That will open the files and folders on the CD.
Among the files and folders, look for a file that has a serial number that you will need to activate the webcam software. It should be somewhere in there.
Hi Jonathanchandler,
The serial number you entered was the manufacturing product number of that web cam. There should be a CD with the web cam. In that CD cover you will get a code in red color label. That is the original serial code of your web cam.
It's easy to find the serial number of the usb camera. You just need to check the cd case you have. Once you have it with you., just find the serial number by checking the red sticker on that cd case. Remember, it is red in color, and it should be put on the opening side of the cd case.
I don’t think web camera software require serial numbers to install. When a serial number is asked during installation, it often refers to the license number or product key and this code has to be purchased. Web camera drivers or software don’t require it because you already purchased the device or the camera itself.
Lenovo USB webcam
Since you have a Lenovo web camera, download the Lenovo Web Camera Driver. It supports Windows XP (32-bit only) and Windows 7 both 32-bit and 64-bit. If this driver doesn’t work on your web camera, head down to Lenovo Find Your Product Support page and enter your camera’s serial number in the search field and hit Enter.
This will allow you to search the driver specific to your camera model. The serial number of your web camera can be found at the bottom or the side of the device itself or you can also check the packaging for any printed camera serial number.
1....
