I am trying to cull out information from the recorded QQ Conversation with my boss last week. I need to get some instruction from our last conversation and there are some details that I failed to note, so I need to go back to the thread and check the information. However, I stumbled into the biggest problem, and that is, I am unable to locate where it is being stored. Simply put, my question is where is QQ Conversation stored? If you can provide me the information, I would gladly appreciate it.
Thank you for your help.
Where is qq conversation stored?
Hi there joby,
In the QQ program there is an icon of a speaker, once you click it a page will pop up where a list of folders will be displayed, click on the desired folder and it will expand, giving you a list of your contacts. Click on your boss's name and the chat history will show on the right side.
The conversation is using QQ is stored in the directory where the program is installed on your computer. You can locate your particular chat history with the use of QQ number which is assigned for every specific chat with respect to the other end username.
There are two ways/paths to access your chat history if it's not deleted which are:
1. C: Program Files Tencent QQ QQ number of your
2. C: Program Files Tencent QQ your QQ number
Path depends on the type of installation of qq software.
Hope it helps you.
You need to register with QQ as a user yourself definitely. Press enter after you type your messages. You can save your written messages in the QQ Chatroom message Window.
