Good Evening Everyone,
I am using MS PowerPoint 2007 in my windows xp operating system.As we all know we can get predefined themes in PowerPoint from the "Built-in" section of design tab, but if we create our self made themes and save them in themes12 folder then i am unable to get my custom made theme.
So I want to save my custom made theme which I can reuse again and again in PowerPoint.Tell me where to save customized in ppt?
Where to save customized in ppt?
Hello Stephen,
If you want to save a customized theme in ppt 2007 than you should follow this instructions. Go to the Design Tab, in the themes group click More. Click save current theme. After that give a name to your file and click save. You will find your file in the document themes folder. And is added to the custom themes.Also you can find free templates and themes from office online. That is a help if you do not want to spend time making themes. I will be happy if this answer help you.
