Where Is the setup for avast audio file placed on Windows 7?
I want to know the default location of avast audio file on windows 7? Has anyone faced any virus warning alerts, once its plugged in to your computer?
Hi, Louise
The audio file for Avast antivirus can be found at: My computer>local disk c> program files>Avast. If you don’t find the file, you will have to download it manually from the Avast website. This feature is an option in the latest versions of Avast (5 or later). Please make sure you have the latest version of Avast. Visit the Avast website (www.avast.com/fun) and you can select the audio files and themes that you like. You will have the option to download the themed audio or the official audio from the website.
Skarbos Jay.
Notifications
