Where should I get a software for WIN2PDF as LPR
I am using Mac OS X, I need a software that will convert MS Office files like Word & Excel to PDF and then will give the Print of the PDF. Where should I get a software for WIN2PDF as LPR.
Hi David,
WIN2PDFÂ software used for converting files into PDF from any Windows.
From here you can download this software and follow the instruction.
Create PDF Files Quickly and Easily!
Install software on your system and load it as new printer and name it WIN2PDF.
Open the application e.g. MS word, excel which you want to convert then select the print option from file menu and select the option WIN2PDF.
Now in WIN2PDF file save dialog box , save the PDF file.
Hi David,
You don’t actually need software to do this job. There is a built in system in Mac OS to do this. Open your file with the appropriate program (Word, excel etc.). Press Ctrl+P to open the print dialog. Click on the PDF button at the bottom left and click Save As PDF.
Choose the location where you want to save the file. Thus you could create the PDF files and also print them.
