Where will get a accessdata registry viewer software for downloading?
I am looking for accessdata registry viewer software. I have Googled it but have not found any download link. I have found only pages with accessdata registry viewer software on different software sites but no download link. Do you have you any link? Please help me.
Best Answer by Kevin Lee
Answered By 0 points N/A #184712
Hello Thomas,
Access data registry viewer software helps you to provide your system registry information.
The registry results show you the full registry details and all of its sections.
By using it, you can manually select keys and subkeys to give a report.
You can download it directly here.
It is only 27.26MB.
Now enjoy it. Thanks.
Johnny Mrmarshall.
Answered By 0 points N/A #184713
Hi Thomas,
I have found a solution for you. I am sure it will help you. Before I go ahead with a link for direct download, I would just like to tell you something about Access Data Registry Viewer.
The Registry is basically a set of data files. The Registry permits the operating system to control all the aspects like Hardware, Software, User's Information, the complete functionality of Windows Interface. The Registry contains a lot of information like username, password, sites accessed, recently used documents or files and folders and the details of programs installed on the computer, different types of registry files set up for Operating system.
The functionality of a Registry Viewer is to view and can access all the information mentioned above.
Access Data Registry Viewer can access data from any system. It also can access protected data.In a nutshell , this particular tool can access all the confidential and highly restricted data from any system.
Please download Access Data Registry software from here.
Answered By 590495 points N/A #326561
The AccessData Registry Viewer is a standalone software that can be integrated with the FTK or Forensic Toolkit. It allows you to view the contents of the Windows registry. Unlike regedit, the native Windows Registry Editor, which only shows the current system registry, AccessData Registry Viewer can visualize the registry files from any system.
At the same time, it provides access to a registry-protected storage that contains usernames, passwords, and other information that is not accessible with regedit. Unfortunately, AccessData Registry Viewer is not free. You also need a CodeMeter USB stick with a valid license to use AccessData Registry Viewer. If you want to try it, download AccessData Registry Viewer 1.8.0.5.
