Whether my computer supports a projector or not?
I am a teacher in higher secondary school. I make power point presentations to make my lessons more effective. I have a very old computer in my home, which I am planning to upgrade to latest version. I have a seminar next week.
I don’t know whether my computer supports a projector or not. I kindly request to guide me to know whether this feature is enabled or not.
Please help me.
Best Answer by Perry Deborah
Answered By 0 points N/A #146016
Hello Joanna,
First of all there are few things that must be clear what model projector you are going to use & the model & processor of your computer. You will be happy to know that you can use any type of projector in your computer. No need to upgrade your computer for this.
Thanks
AKerly Joqw
Answered By 0 points N/A #146017
Hello, Joanna A Speer!
I have good news for you. There is no need to upgrade your computer for this kind of job because any kind of projector is supported by your computer. Just connect your projector to your computer with a VGA data cable, whether or not your monitor is plugged-in. It’s a very easy job. I think you will be able to do it easily.
Best of luck.
