Which Android Application is best recommended for managing your disk space?
Is there a better android application one can recommend for Android Smartphone users to help get rid of any junk and also to create space when necessary without issuing any manual command? I have tried quite a number of Android apps that for some reasons I would not want to disclose to you and the church. I hereby seek for your solution to this. Thank you.
Answered By 10 points N/A #200313
Saving phone memory is one of our major concerns.
It is tiresome, to, every time select a file and delete it manually.
Hence android has published an app call “Clean Master” which could remove the junk files and create space in your phone automatically. It not only just creates space in your phone memory but also extends battery life, cools down your phone battery and boosts its speed.
