Which anti – virus is best for my new android
I have an ideos android phone and I was wondering which anti – virus would be the best to protect my android from the the applications I download on the android store?
I have used a lot of android devices and almost all of them were protected by some sort of antivirus software. Recently I am having the AVG antivirus in my Samsung Galaxy S.
I think that its the most unique and easy to use antivirus in the market available. The reason is that every option is written clearly from which you can perform different actions easily.
After that if you still want to try a second device then you can always go for the ANTIVIRUS FREE application. It's also a handy application but is not as feature rich as the AVG is.
Hello Quiqui,
There are many antivirus that you can use on your ideos phone, and there are:
The one that is outstanding among these is Avast. It offers various security tools that you will like some which are the antivirus, a web shield that scans the urls you access on the internet, a privacy advisor, various antitheft options and an app manager.
Avast automatically scans the existing apps to check if they may be infected with malware when you run it. After the scan it turns to a real-time protection mode. It is the best antivirus software for Android according to the tests carried out by Android.
Carl
Hi Quiqui
There is another Techyv post which is addressed your problem . Check out that page and get more idea to fix this issue.
