gish001
120 points
Posted on - 04/20/2011
I am facing some Spyware issues in my system and I have searched on Google but it was not much help there.
Please suggest a good Anti spyware program which can firstly clean existing Spyware in my system and also protect from future invasions.
Gish
fkutsua
Which antispyware software works good in your opinion?
Dear Gish,
There are some very good Anti spyware programs but they aren't free and they don't work good as well. I will recommend you Spyware Search and Destroy . This is a very good and reliable Anti spyware program which can help you. It can also protect you from Trojan horses and Spybot etc.
Fkutsua
gish001
120 points
Dear Gish,
Thanks a lot for the help. Please tell me more, if this software has any special features in this program, and also I am having this pop up which repeatedly popping out from the taskbar and shows some bad pictures. I want to get rid of it. Regards.
fkutsua
Dear Gish,
"Spybot Search & Destroy" is a very smart software. It will sit back silently monitoring all the processes and will take care of every Spyware in your system. The above popup that you mentioned will be tackled very easily through it. It will scan and then stop the service or process which is infected. I will highly recommend you this software. It's easy to install. I hope the above will help you.
Fkutsua
gish001
120 points
Dear Fkutsua,
Thanks for the help, I really appreciate it.
Gish
rose lee
I still don't know the best Anti spyware nowadays. Maybe Avira. We can get free Avira. That's the only thing I can say right now. I will let you know if I already know the best Anti spyware.
mikeys
Hello Gish,
I am offering you IOBIT360 for your spyware issues on your system. And I think they are upgrading their software now into (IMF) IOBIT Malware Fighter.
This is not only for malware but also for spyware. And Combined it with a Advanced System Care this software has a feature for Registry Repair, Spyware scan and repair, System Optimization and much more. So then if you already have that two software then install it, and do not forget to install first your antivirus and what I do prefer is Avira Antivirus.
1. Install Avira Antivirus then Scan after that update it. All drives.
2. Install Advanced System Care then Scan and repair it. Full Scan.
3. Install IOBIT360 or Iobit Malware Fighter then scan and remove it. Full Scan.
Until now I have been using that on my repair shop. I wish it could help you. Then you're always welcome.
Mikeys
lee hung
75 points
Microsoft Windows Defender this the best spyware. It is easy to use no need a serial.
It is a free software.
You can download in Google.
This kind of software.
