Which antivirus is the best one?
When we look for the best Antivirus software we have to compare a lot of things. I know I have also faced this type of problems. Sometimes it gets really tough to find out which one is the best because most of the Antivirus software’s says they are best in the Market. But they do not provide all types of security.
But if we try to think a little bit deeply we would find out some hidden feathers that a few Antivirus software provides. Because “Antivirus" means a utility that protects against all kinds of malicious software. It doesn’t’ mean that only the virus but also Trojans, Spyware, Adware, Scareware Rootkits, keyloggers. A best featured Antivirus must cover all of them.
At present the ranking of 5 best Antivirus software goes like this:
1. Bit Defender Antivirus Pro 2011
2. Kaspersky antivirus 2011
3. Webroot AntiVirus 2011
4. Norton AntiVirus 2011
5. ESET Nod32 Antivirus 4
** I would like to suggest you to use Bit Defender Antivirus Pro 2011 for your PC security solution**.
Well as present Bit Defender Antivirus Pro 2011 and Kaspersky Antivirus 2011 are the most trustworthy Antivirus on the net and they are fighting a lot for your attention.
The reason for choosing Bit Defender as a PC solution software and reviews of other similar software’s are given below so. So it would be easy for you to compare it with other software find out the best one suitable for you.
1. Bit Defender Antivirus Pro 2011.
BitDefender Antivirus Pro 2011 The Most popular and comprehensive and flexible set of Software. This is powerful and well balanced software provides all the essential security for you.
Bit Defender Antivirus Pro 2011 got the Gold Award winner for best antivirus software in the market, 2011. And it is the best selling antivirus software on the web.
Price: $29.95 also offers 10% Discount on coupons.
Fractures and Protection process:
Protects from a number of viruses, spyware, phishing scams, and more on.
Covers you from every angle, protecting from threats on the internet, email, etc.
The program scans all web, IM, and email traffic for malware.
Encrypt your IM chat conversations.
Ability to configure a home network.
Successfully detecting, blocking, removing, malware infections.
Doesn’t hamper internet speed and it optimizes operations and maintains maximum speed.
New Features:
The Search Advisor which provides protection while surfing online.
The Active Virus Control will lock all the malware coming in your way.
The secure gamer mode that turns off any interruptions.
Installation Process:
Easy to install and user friendly.
Available in box or can be downloaded from online.
Very quick and easy step-by-step instructions.
Doesn’t require a reboot.
Updates:
Updates Automatically.
Run in the background.
Doesn’t slow down your PC.
Lacks:
The software is a little heavy on the resources or PC although this problem is not faced in most of the computers.
Third-party industry testers and reviewers (Virus Bulletin VB 100% Certification, ICSA Labs, Consumer Reports, West Coast Labs, AV-Comparatives) says that BitDefender is one of the best of the top ten antivirus applications.
2. Kaspersky antivirus 2011.
Kaspersky Lab's products are the best solution for your home and office security. It is specifically designed to provide easy to use and quality protection.
Price: $59.95.
Designed to protect from angles, threats from the internet and email spyware.
Effectively detect, prevent and remove all sorts of malware.
Protect from traditional viruses, as well as new threats.
Backup and Rescue Disk facility.
URL Advisor for safely surfing.
Set preference’s.
iCHECKER and iSWIFIT build to scan technologies.
8. Virtual keyboard and gamer mode.
New Features
The System Watcher, which monitors and log application activity and behavior. If something suspicious is detected, the software stops the process and informs the user.
It can also delete malware created in the process.
Desktop security gadget.
Easy to install and interface is user friendly.
Includes three licenses.
Even can install if PC is affected by virus already.
Update
Updates on a regular basis.
Update may slow down your system. But it doesn’t feel at all in many PC.
First update may take several times.
Update scheduler is present.
Lacking:
Sometimes it may slow down your system and downloading big update files may be the reason for such slow down. Although this problem is not faced in most of the computers.
May detect some of the pirated software and disable them.
3. WebRoot Antivirus 2011.
One of Best anti spyware solution with Spy Sweeper for an effective one-two punch against malware.
Price: $39.95.
Spy Sweeper protects from threats, finding malware from several sources.
Many layers of protection keeping away All sorts of worms, Trojans, malware, and rootkits.
Removes malicious files.
Protected from intruders & thieves.
13 protective shields covering networks.
Email shield protects from unwanted emails.
Capable of protecting from 100% of known viruses.
Designed to run smoothly.
Color-coded theme.
New Features:
“Zero-hour” protection process keeping safe from malicious activities.
Spread awareness by providing information about new threats.
Gamer mode.
Easy to install and implement.
Restart not required.
Recommends full scan after installation.
Webroot Automated Research Network starts with the installation process.
Updates:
Automatically checks for updates.
Updates are delivered to your system.
**WebRoot Antivirus 2011 is approved by ICSA, and certified from the West Coast Labs as an effective solution for desktop antivirus, anti-trojan, anti-malware, and antispyware.
Lacks :
Doesn’t encrypt IM chat conversations.
Missing laptop mode and link scanner.
4. Norton AntiVirus 2011.
Norton 2011 having comprehensive features and rock solid performance. And improving day by day.
Price : $ 39.99.
Provides coverage from all angles.
Protects from viruses, Trojans, worms, bots, spyware, rootkits, intruders, and other malware threats.
Supports a large number of browsers.
Norton’s huge database of malware will keep the computer safe.
Continuation with Norton Insight technology.
Involves a special algorithm to analyze files and determines threats.
A warning popup appears when a threat was detected at the time of download.
Best for set-and-forget security solution.
New Features:
SONAR 3 stands for Symantec Online Network for Advanced Response which detect Malware.
Trying to find out at last 1% of viruses that are new to the others Additional vulnerability protection and it helps to protect from many patches.
Norton Power Eraser that removes the fake AV software.
Easy to use and understand.
Provides direct download facility so starts from the second you download the program.
Straightforward and quick.
Updates:
Update done every 5 to 15 min.
Small update file.
Manual update.
Lacks
The innovative technology isn’t a specific tool or feature comparable to others.
Doesn’t uninstall properly.
5. ESET Nod32 Antivirus 4.
ESET Nod32 Antivirus 4 providing advance security but lacking in some department.
Price: $39.99.
1. Protects from traditional threats like viruses, worms, Trojans, spyware, and even rootkits.
2. Works behind the scenes.
3. Provides email protection to scan email.
4. Scanning external devices when plugged in.
5. Can create a bootable disk.
6. Speedily process.
7. Scan file in real-time or to access.
New Features:
1. Virus Bulletin.
2. Energy-sipping battery mode for laptops.
1. Easy to install and implement.
2. Works from the very beginning of installation.
3. Setting up manual scans.
4. Simple user interface.
Update
1. Updates automatically.
2. Small update file.
Lacks
1. Isn’t as far-reaching as the upgraded Smart Security software requires.
2. Lacks some features from other popular Antivirus software’s.
3. Not having a good interface.
Here I have included all the information regarding the Which antivirus is the best one. So now you can understand why BitDefender 2011 is the best antivirus at present. I hope it would be helpful for you.
