Which App Consumes a Lot Of Battery Power on Laptops?
10 points
Posted on - 11/14/2014
I would like to know if apps consume a lot of battery power when it is used in laptops. Does the type of application being used affect the battery-life of the laptop? If it does, could you explain how this process of excessive battery consumption affects the power level of the laptop?
