I would like to know if mobile app consumes a lot of battery power when it is deployed in tablet PC. Does the type of application being used affect the battery-life of the tablet? If it does, could you explain how this process of excessive battery consumption affects the power level of the tablet PC?
Which App Consumes a Lot of Battery Power on Tablets PC?
There has been a research for Apps' battery consumption and it is considered as a top 1 in this light. The famous social app Facebook is considered to topping all the other apps in battery usage. Generally, Apps directly affect the battery life of our gadgets. We may notice sometime that at times it seems like you never have enough battery and everyone else’s seems to have the same battery problem. This always happens than we care to think about. The truth of the matter, our gadget having more than a year old, it’s probable that our battery could no longer last for a day. And another cause of this aside from Apps draining our battery are the extreme temperatures. Extreme heat and cold affects the life expectancy of batteries. Lastly, batteries die at a given time and the way we expose and use it will determine how long it will serve its purpose.
