R Ocampo
10 points
Posted on - 07/20/2016
Hey guys,
There are many Security Apps for Android and probably, this is the reason for my confusion. I am not able to decide the app that I should go for. I need someone’s help to find the Best Free Security for Android.
JSalceda
Which App Provides The Best Free Security For Android?
When you choose an Application that affects the security of your Device then, go for the one that provides its updates regularly. New threats are created almost every day.
Avast Mobile Security and Antivirus will be the best option, in my opinion. It is the best Security App for Android Devices.
There are many extra features that no other App provides on Security basis. The Anti-Malware protection of Avast is flawless. The free version of this App is better than the premium versions of many other Security Apps. I would suggest you to go for it.
