I was told that there several apps that cannot be enjoyed by the Android users. Is this the major cause for the huge marketing drift between the Android OS and Apple OS? Do both the users get the same privileges of the apps used in their devices? Can anyone please help?
Which are the apps that are available only to Apple devices?
I guess you are wondering about the availability of mobile phone apps for Android and iOS devices. It is true that sometimes an app is not available on the other mobile phone operating system and sometimes both iOS and Android are supported. I guess if you want to blame someone, it should be the developer of the app.
Android and iOS shouldn’t be blamed when there are applications that are not available. They don’t create the apps. They are only the platforms or the operating systems where the apps run. Maybe, if a user likes an app in iOS and also has an Android phone, he can ask the developer if they can create an Android version of the app.
That’s probably a good start and who knows the developer might consider the request and decide on designing an Android version in the next release.
